Patriot XL and dihedral measurement
I finally cut my wing in half to correct the misalignment of the incidence. Before to separate it, I measured the dihedral with one panel flat on the building board. The other wing panel was 2 and 1/6 inch (measuring from the building board to the superior portion of the trailing edge). Can anybody confirm this value? Also, what is the incidence of the wing when it sits on the fuselage?
Thanks a lot, Le fou |
