Link to military drones in Norway
1 Attachment(s)
I thought this was a pretty cool web page showing Norwegian military drones for target practice. Check out that launcher about half way down the page. That ought to get a Whiplash in the air without the engine even running! The biggest drone is a delta with a 138 inch wingspan running a 70hp Wankel engine.
-Tom Norwegian Military Drones |
seems like a terrible waste, all that radio gear and a os 140 rx, brings a tear to my eye
Indeed... :(
Maybe I could contact the Norwegian military to ask what they do with some of that stuff after it has been shot down...there's bound to be something left of it... Using Hatori pipes for target practice... :mad: |
target drones
If somebodey is interesstet on such a moster speed modell, who is able to go with garantie 400 mph ++ .
I sell excactly this Delta fully carbon with a brand new rotary engine from uav . If you need information please have a look at http://www.uavenginesltd.co.uk/ you will see the engine type 731 with 38 hp. The delta have a span of 100 inc. is 120 long. weight ready to fly with 22l liter gasoline mix 50:1 55 kg. Is its fully built in cfk in 1a molds. The normal military price is over 30 000 dollar I am asking for 8 000 dollar. Best regards Michael |
Military Drones
Hi Michael,
Not that I want to order one, but do you have any pics of the delta model that you can post? These things are waaaaay cool. I'm sitting here with my jaw open saying "whoa". -Tom |
Make sure you have someone that can give you a good neck-massage when the flight is finished... :D :D :D
22 litres of gas...that's about 5 gallons! That should last you about an entire day... |
You think the "Banshee" looks cool on picture?? You should see it live!
I flew drones when i was in the army, and that was one fun year! An even better page is this one: http://www.jerofuel.no/dro.htm It's in Norwegian, and is written by Per M. Strømmen, the second in command of the Norwegian Drone Service (He served as a regular pilot the same year i did). It basicly says: The large drone is a Banshee 400, produced by the British company "Meggit Defence System Limited", and that it has been in use for 13 years in 25 countries. There has been made 2500 Banshees. It's a multi-role drone with possibilites to carry smoke-cannisters, stationary flares on the wingtips (to attract missiles i guess), and drop flares (the usual way). It can also be fitted with a camera for recon and UAV-missions. The Banshee is launced by a catapult, and is recovered either by parachute, or bellylanding it. Wingspan: 2,49 meters Length: 2,84 meters Height: 0,71 meters Weight: 54,5 Kg. MTOW: 70,3 Kg. Fuel: 17 liters og 100LL AVGAS Speedrange: 75-400 km/h Endurance: 1:20 Payload: 16 Kg. Banshee is used mainly as a missile-target for the Navy, and mostly missiles like Sea-Sparrow and Mistral is used. It has also been used as target for the laser-guided Robot 70 in Norway. It's about to be introduced to the Air Force as a target for the F-16's and their Sidewinders. The Banshee can be operated either manually within visual range, or with autopilot and telemetry. It has to engine-options: A 350 ccm boxer (26 BHP) driving a 24x27-prop, or a 250 ccm wankel (39 BHP) driving a 26x30-prop. The a few words on the light-drone "MATS-C" that is built in Norway. I flew these my self, and it's a very basic model with a fibreglass-fuselage and a OS 1.40RX for power. They switched from OS 1.08 to the 1.40 while i was there, and that was most certainly a positive change. The MATS-C is used for target-practise with everything from light personal weapons to 40mm AA-guns, and it can sure take a good beating before you end up using the parachute for recovery (or bellylanding it). We'd just patch it up, and send it up again, so one got used to quick field-repairs. It has no rudder, reaches maximum speed at 170-180 km/h, and has been flown in winds above 20 m/s, and handled it better than the pilot (Iv'e tried 28 m/s wind with it myself, and it was easier to keep in the air than on ground as it was way above the stallspeed). |
FUN!!!
I believe you...that must have been one fun job.
Still a shame of all the equipment from a modellers point of view though. This is the ultimate "combat" experience... Could you fill us in on what equipment they used on the big drone? Servo's and stuff? On a plane that size you would need some bigger than standard stuff... |
Monster servos
Vantec SSPS105 Servo
These are Seiko servos. They have 27 ft/lb of torque! That's over 5180 in/oz of torque. You'd have to gang up over 123 standard servos to get that power. It's $524 at Vantec.com. They were made for the RPV's and UAV's. I had an idea to use these to fly an experimental plane via remote control. They could definitely handle it. They weigh 27 ounces each but what a beast. I bet that large delta model could be flown with these servos. Vanteck SSPS050 servo They have 690in/oz of torque and are $194. Of course my favorite monster servo is this one, it's only $40 and has 325 in/oz of torque. Hobbico CS-80 Giant scale servo I used three of these to convert my self-propelled lawnmower to RC operation. You can see it here: Wingspan99's RC lawmnower |
A mate of my once converted an old Citroën 2CV to rc...he built his powerservos himself however.
That thing was quite an attraction... |
hmm.. I'm a big wankelfan..
Wounder if you could get you hands on one of those engines after they shot them down..? //magnus |
Hi Magnus
I think not.. If it's damaged they'll fix it, but if it's destroyed, well then it's no good to anyone... ;) |
If you knew the man who decides wether something is total loss or not... and then smuggle it off the base... :p
Ramprat
Where did you fly drones? Out by Ölberg outside Sola or? Drones are also being used chasing birds at Sola Airport Stavanger(Norway).At least they were going to try. |
Originally posted by RampRat Hi Magnus I think not.. If it's damaged they'll fix it, but if it's destroyed, well then it's no good to anyone... ;) I would likle one even if its destroyed!*s* wounder what make they are.. any one know? //magnus |
Rudeboy:
A bit hard with those big wankels, but i do have a couple of OS 1.08's that i don't seem to remember buying... ...and for some odd reason, that's what they used on the small drones back when i flew them.. ;) ..until they were replaced with the OS 1.40 RX.. Forus: I got my training at Vigdel by Sola, but was sent to Fredrikstad after that. |
Wankel engine
If somebody is interessted I have
1 brand new Wankel drone engine with 38 hp for sale and 1 used one only for collectors. The new one is direkt from the factory in box with instructions manuel for 3000 Euro ( normal price is 3230 english pound ) at factory. The one for colector is 700 Euro. I also have a drone for sale the fomous Baccee the last version full carbon. It is never flown and in perfekt condition. Please give me a mail if somebody is interesstet. [email protected] |
Target Drones
1 Attachment(s)
You dont have to go to Norway to get Target Drones, Aerojet Composite Models makes several versions for the military.
heres a couple of "shots" no pun intended The "Backlash" originally slated for public sale, now being developed and used for Target Drone service and UAV w.s. 72" powered by an OS BGX 80-120 mph |
Target Drone
1 Attachment(s)
Our second drone the "bullseye"
w.s 100 inch 50-80 mph power US41 (can use up to DA100 size engine) |
another shot
1 Attachment(s)
heres the 2 drones together waiting to be killed.
1 Attachment(s)
Rrrrr, looks nasty on those engines, being out in the wind on that beach... but I guess it doesn't matter if they're going to be shot to pieces anyway...
glow
It certainly wasnt the optimum environment for the engines.
gas/glow + sand = chewed up cylinder walls.... It was that really super fine sand too... we did cover the carbs however.. :stupid: |
Wait untill they see our new one. eh Rick
over a 12 ft wing span LOL. pirate: Chris |
