Speed estimate for my CG Extra 300
Hi All,
I was hoping to get a speed estimate on my Carl Goldberg Extra300. It's the .60 to .75 size. Built it 9 years ago. It weighs 10.5 lbs, has an OS 1.08 (2 stroke) engine and a 15x8 prop. http://www.carlgoldbergproducts.com/.../gbga0055.html Can anyone say what speed it 'should' go full out? edit: also a pitts style muffler |
RE: Speed estimate for my CG Extra 300
80.
Mine was clocked at 65-70 via doppler with the same engine and a 16-6 APC prop. I installed a perry pump and would estimate another 5 mph.
80 would be real close with that prop combo |
Hey gun that pump should only give your more if the carb "is" too big to draw fuel on its own or you open the carb up. i run pumps on all my 45 and planes if it will fit.
Sorry, but I forgot to mention that I have this style muffler on it also: http://www3.towerhobbies.com/cgi-bin...?&I=LXFH39&P=7
I guess I was way off on my speed estimates. I was thinking around 100 mph+ :( |
80. Sorrry, it's not a speed plane... You may get 90 full power in a dive but that would be a bad thing for this plane.
ORIGINAL: airraptor Hey gun that pump should only give your more if the carb "is" too big to draw fuel on its own or you open the carb up. i run pumps on all my 45 and planes if it will fit. I put the pump on due to the Pitt's muffler and a leaning out problem, I never dopplered it after I insatlled it so it's just a guess if it's faster. It seemed that way to me but I could be wrong. My 1.08 is old and tired. I saw a guy get a new 1.08 on e-bay last week for $120.[X(] Mike, You might be able to get 100 out of it with a 14X12 or a 13X13:D Might remove the wing in the process though.:D:D |
those 108 are very strong engines do a little transfer work and raise the timing with a jett 120 muffler and have a screamer.
The problem is the old kit .60 E300 is not meant to go fast.
The trick to an inverted or side mounted 1.08 is to use a fresh OS F plug. The pump helps too... but the trick is the plug. |
