fuel pump issues
Hi all
After pumping fuel into my tank with my electric fuel pump for my ross 45, after it is full and i disconnect, the fuel line for the engine squirts fuel all over. does the fuel pump put to much air pressure in this small 8 oz tank or what is the problem |
fuel pump issues
Do you see the fuel going into the muffler through the pressure line when it's full?
Do you have a check valve or something in the pressure line? Does it really squirt, or just dribble out? If it doesn't really squirt, it might be related to tank location. |
fuel pump issues
...and if it does squirt, i would check the pressure-line going to the muffler... It may be clogged and need replacing...
| All times are GMT -8. The time now is 09:09 PM. |
