Help!!
I have a Walkera 450DO and I'm a newbie.
I was messing with heli when I first got it and when I spooled up and it started getting light it started to tilt on its side. I thought the 3 axis gyro was supposed to correct this, am I wrong? I realize that on flybar helis you have to counteract this tilt but a 3 axis gyro is supposed to do it for you. Help! |
RE: Help!!
Did you let the gyro arm and initialize?? If not, when your TX is turned on and of course binded, apply your power to your 450, and set in on a level surface. Don't touch it. Usually if you do not touch your 450 for a while, I wait at least ten seconds, and you should get a solid LED from your mixer, letting you know that it has initiallized, this should correct the problem. Let me know what your results are ! - Drone Ace
| All times are GMT -8. The time now is 03:05 PM. |
