Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
Reload this Page >
*GP Extra 330SC 3mm Foam 3D EP ARF*
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 01-22-2011, 04:25 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Default *GP Extra 330SC 3mm Foam 3D EP ARF*
I'm looking at getting the Extra 330 SC with the stock 250 motor. What kind of flight time can I expect with the 7.4V 2s 300mAh LiPo? Any issues with the plane or the build?
I've been looking over the manual and since I've never put a foamie together I have a question. When glueing the Vertical Fuselage, Aft Horizontal Fuselage, Forward Horizontal Fuselage, and fuselage stringer together just how much gluing is required? Should the entire seems be glued or just glue it about every 2" or so?
Old 02-20-2011, 03:29 PM
Tsavah
Default RE: *GP Extra 330SC 3mm Foam 3D EP ARF*
I glue the entire seam of all parts if I expect them to stay together. Skipping space between parts is a weak spot. Try glueing spare/scrap foam parts in the butt joint fashion using both glue seam methods. After each test sample is fully cured, stress test the joint. See which one holds up better and you will have your answer.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
