SuperFly-E can now be built as a pusher
My Feedback: (12)
I just updated the instructions for the SuperFly-E, it can now be built as a puller or a PUSHER!
The plane flies nice as a pusher, better than I thought. The only thing it won't do as well as the Puller fly really slowly while being supported by the prop. It is kind of nice to have the motor, prop and gearbox protected.
I have put some pictures and video up on the site,
www.SuperFlyRC.com
David
www.SuperFlyRC.com
David
My Feedback: (12)
Prop
With the prop horizontal it is up out of the way when the plane is laying flat on the ground. If you come in and kill the throttle the prop will stop somewhere in it's arc. If it stops pointed staight down and it hits when you land it simply rotates until it is out of the way. I have done several full throttle landings and the prop just beats up the ground. I am sure it would break if you tried landing hard on pavement with the throttle up. The GWS prop that comes with it is pretty flexible, I haven't broken one yet since I put it on the plane. Take a look at the last video under the SuperFly-E videos page, I try to land on a tent then fall into the dirt. Prop was fine, ego was hurt a little....
Hope that helps,
David
www.SuperFlyRC.com
Hope that helps,
David
www.SuperFlyRC.com
Hi David,
It looks neat, but, to be honest, I am completely "hooked" on the standard SuperFly-E tractor configuration. I can do stunts with it that you just can't do with a pusher...and I have plenty of those.
As long as you have intermediate pilot skills, the tractor version is a blast!
Regards.
Regards.
