Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
Reload this Page >
What is the hottest 400? This one?
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 10-04-2003, 04:47 PM
Wingman33
Default What is the hottest 400? This one?
So what im thinking here is this jet needs more power and less weight check out the 4,8volt motor compared to standerd 400 motors38Watts short af a astro brushless withTWO less cells lighter . what doyou think.??Specifications : From the Graupner site,
Motor
ref. Watts
Volts
7,2V (GR1794) 35Watts 8,4 Volts
6V (GR3321) 35Watts 7,2 Volts
4,8V* (GR3320) 50Watts 6,0 Volts
astro020 (802) 88Watts 8,4 Volts
Old 10-04-2003, 08:35 PM
Wingman33
Default RE: What is the hottest 400? This one?
Hobby people ,or Hobby lobby both sell this motor .I just orderd one and will present comparison With the Trick Revers time motor a 6volt Multiplex and a standered 6volt when i get the Graupner its a little pricey for a 400 at 14.50. Mike.
Old 10-10-2003, 07:38 PM
Wingman33
Ok got my 4.8 volt 400 from Graupner this is definetly the hottest wind brushed motor 22.000rpm at 4.8 volt hotter than the Rocket 400. it could be used as a hop up on a LIGHT plane mabey the micro jet,you could go with higher mah cells and less of a cell count or just less cells for less weght . mabey geared to let it spin at a sweeter RPM Testing will continue.......
ID:	66907   Click image for larger version
Old 10-11-2003, 05:37 PM
Wingman33
Well I was running the permax 400 2/1 geared on a wing with eight 2/3 a 1100s. about17 amps im guessing 5min flight times. tommarow i am going to put the graupner 4.8volt 400 in it, as the 6. somthing, did not even get warm though my batteries were quite toasty.mabey 100 watts tops. I must admit i can only get so excited with a hot 400 gear set up as i fly 400 watt cobalts in my other wings. Mike B.
ID:	67004   Click image for larger version
ID:	67005   Click image for larger version
ID:	67006   Click image for larger version
Old 01-12-2004, 06:59 PM
Wingman33
I saw a guy yesterday ask what a good gear drive for a zagi is ,and I rememberd this thred the gear dirive is a Wattage 380 drive fits 400s 16 dollar with steel gears will not strip.From Hobby people. Mike Burns
Old 01-19-2004, 11:01 PM
oldpilot
CHECK OUT THE QRP Hyper 400 Motors. These are the hottest brushed 400's I know about.
http://www.aircraft-world.com Click on Products - Motors - page two - Motors 400 specs and prices. (EG: $9.80 US)
BTW Aircraft-world have a $2.50 US shipping charge, Airmail, Worldwide, for all orders up to I lb (455 gm)
Cheers. Patrick. [8D]
