Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
Reload this Page >
what can i use to cut this foam?? (pic)
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 05-24-2004, 08:47 PM
3dandpatternflyer
3dandpatternflyer's Avatar
Default what can i use to cut this foam?? (pic)
Im only 15 and don't have access to a CNC maching or anything like that....I tried scissors at one corner but it flatens the foam too much. What do u guys use to cut out pieces from foam?
This is my first time ever building from plans. So I;m new. Its gonna be a KatanaS from www.3dfoamy.com
TTYL,
Andrew T.
Old 05-24-2004, 08:58 PM
rdcracer
rdcracer's Avatar
Default RE: what can i use to cut this foam?? (pic)
I cut out the plans with scissors then tape them to the foam in various places. I then use an exacto knife on a wood surface. NOT YOUR MOMS DINING ROOM TABLE!(experience talking). If you take your time it works real good. PATIENCE!
Old 05-24-2004, 09:06 PM
3dandpatternflyer
oh ok
I guess ill try that then. Thanks!
LOL
Old 05-24-2004, 10:21 PM
crewchief_432
andrew what plane is that.
Old 05-25-2004, 01:20 AM
FNG
FNG's Avatar
ORIGINAL: 3dandpatternflyer
TTYL,
Andrew T.
Old 05-25-2004, 08:50 AM
3dandpatternflyer
Its a KatanaS from 3dfoamy
Old 05-28-2004, 09:00 PM
3dandpatternflyer
i used the modeling knives from wal-mart. They worked really good, but took about 2.5 hours!! I still need to use sand paper to get the edges right...
Thanks Everyone,
Andrew T.
Old 05-28-2004, 10:00 PM
rlpfly
The best thing I have found to cut fan-fold, Depron,ect. is a heated #11 hobby blade.
Lowes, Home Depot, sell a Weller soldering Iron kit that includes a fitting that holds a #11 blade.
Makes perfect cuts every time,only cost about $13.00.
Rlpfly
ProBro #117
Old 05-30-2004, 05:27 AM
whackinski
whackinski's Avatar
3D, You have to find a nice piece of glass to cut on. A glass door from an old entertainment center works great. Get a box of 100 blades because you must change the blade often while cutting foam. I use glass when cutting Monokote as well.
The hot knife Idea is also very good, I made one from an old solder pencil.
Old 05-31-2004, 12:02 PM
3dandpatternflyer
Why glass??
Old 05-31-2004, 02:33 PM
whackinski
whackinski's Avatar
Glass has no give the blade meets the glass and does the job without getting misdirected. If you cut on a soft surface the blade gets misdirected. Try it, get a small piece of glass and make some cuts, you will see for yourself.
I have the luxury of having an AMA hall of fame-er in my club. Vertical ts's uncle, who has been on several AMA mag covers. He is a premiere builder and will have a more defined answer as to why. I picked it up from him 20 years ago. It's good for cutting covering material, balsa, foam just about everything.
Good luck
Whack
Old 05-31-2004, 02:43 PM
3dandpatternflyer
yea! your right, makes sense!
thanks,
Andrew Tzers
Old 06-04-2004, 01:42 AM
jtech
jtech's Avatar
Try the glass for a cutting surface; it's the best!
Old 06-09-2004, 08:38 PM
3dandpatternflyer
heres what i got so far.... Planning to use a Himaxx 2014-5400 in GWS "D" gbx. Almost Finsihed!!! [8D]
Old 06-13-2004, 04:28 AM
ninja neb
ninja neb's Avatar
try heating the blades a bit just make them a bit warm dont burn the foam what ever you do
it shouldcut easier and quicker
Old 06-18-2004, 09:51 AM
Tommygun
ORIGINAL: whackinski
How did you attach the blade to the soldering iron? Can you post any pics?
