New foam bipes?
TX
New foam bipes?
anyone flying the new Chip Hide bipe,,or the Hellraiser?,,like to know more before i buy one or the other,,flying the Ultimate bipe now but am wanting a newer one,,thanks,jim
RE: New foam bipes?
I have been flying the Hellraiser for about 2 weeks now..........all I can say is it's truly awesome!!!!!!!
My set up is as follows:
Futaba 9Z transmitter
AXI 2212/34 motor (only draws 5.9 Amps at full throttle)
Jeti 08-3P speed control
APC 11x4.7 SF prop
Hi-Tec Electron 6 receiver
4 Hi-Tec HS-55 servos (one on each aileron so I can have flaperons. Do this...it's well worth it!)
Thunder Power 1320mAh 3 cell Li-Po
Kokam 1500 mAh 3 cell
3D is amazing........flies 20 min hard 3D.....1/2 to 3/4 hr cruising on Thunder Power....longer w/ Kokam!
Get one.........you'll love it. Elevators extremely well, by the way.
Scott
APC 11x4.7 SF prop
Scott
TX
RE: New foam bipes?
got my hellraiser about 2 weeks ago (finally),,and you are right it is awesome,,did not get the 2212/34 (lobby sent the stock 2208 instead of) but it works just fine,,,not as durable as the Eflight bipe but it is so quite and with the new Kokam 1500mAh3s,,it is hot as i need,,thanks for the advice and fly good,,jim
GA
RE: New foam bipes?
Just bear in mind that with the Chip Hyde Raptor, you will need TWO aileron servos to get the most out of the plane. Mix the ailerons as flaperons, and watch the thing do WILD stuff.
