Need more time!!!!!!!!!!!!
CA
I need more flight time will a 8c batt with more mah give me more thinking about going to LHS and have a 1800mah made if they can do that.
GA
RE: Need more time!!!!!!!!!!!!
what plane? esc? motor?
the voltage need to be in the same range..then you need to think about weight.... also... if you just pop a really high mAh battery in...it "could" shorten the life of your compenents.....
more info might get a better answer
