Tribute buying help
Tribute buying help
Hello everyone I went to my local air field today and a few guys from the cloud clippers showed me a e-flight tribute. It was love at first sight. So i am on a mission. Sell my hopped up e-maxx and buy a tribute. He showed me some of the electronics and made some good recomendations. I have a few holes i need filled tho.
Phoenix-10 ESC only $59.95
Park 370 Brushless Motor 4100Kv $47.99
Tribute EP 3D Profile, ARF [EFL2000] $44.95
Foam CA 1oz/Activator 2oz Pack $14.24
11x8 Slow Flyer Prop $1.75
1320MAH 3-CELL 11.1V LIPO, 16GA [THP13203S] $52.95
Ultra Micro Servo HS-55: FUT [HRC31055J] $16.95x4
Laser 6 $134.99
Need a micro reciver
Need a charger for 3 cells cheeper side budget in mind but
doesnt take all day....
what else am i missing?
remember i am a complete n00b
Laser 6 $134.99
RE: Tribute buying help
Make sure that Radio you buy is on 72MHZ which is made for aircraft use. 75 MHZ is for cars and boats only. Sounds like everything else is ok. It's a great flying airplane. I loved the way mine flew. I'd also look at purchasing a radio such as the JR 6102 that comes with 4 micro servos and the receiver for 239.99. It's a 6 channel ten model memory. The Lazer 6 you mentioned has two standard size servos that you will not be able to use on your Tribute.
Bevo
Bevo
well I'm more worried about the price then anything else. i will not be going into glow or gas air planes. i will only use the foamies. the price is right and the gas ones take more time and money then i want or are able to spend since the new baby. I need something basic 6 Chan's so i don't have to replace later if i get more fancy ect. would be nice if it came with a sub micro receiver and servos but its not necessary. What about chargers?
VA
The JR 6102 radio is available with micro or sub micro servos and the great 610UL Rx. I use the 610UL in my Eflite Ultimate it's small and light.
I really like the Astro 109 charger I have. It charges quickly and has been flawless thus far for me. It's also very easy to set. Plug the battery and turn 1 knob you're done.
I'd also consider an outrunner motor. Like the HiMax 2812-0650 or 0850. I use the 0650 and it's great. Very quiet and no gears to break. Pulls the 14.4oz Ultimate straight up very well with an APC 11x4.7 SF prop and gets 20+ minute flights of mostly 3D. I would get the 0850 next time though for just a bit more power.
OH
You could look for the E-Flite 20A brushless ESC, it would be cheaper. I'd go for the Himax outrunner as well, I ordered mine for my Ultimate for the stick mount.
-Jeff
-Jeff
VA
Here it is:
http://www.horizonhobby.com/Shop/ByC...odID=JRP6654**
Unfortunately no pic of it. Just look around the site or seach on www.horizonhobby.com to find the receiver and the 6102 pic.
ok i was just looking on horizonhobbies... what do you think?
Tribute EP 3D Profile, ARF [EFL2000] one
Ultra Micro Servo HS-55: JR/RCD [HRC31055S] Two
Park 370 Brushless Motor 4100Kv [EFLM1000] one
1320MAH 3-CELL 11.1V LIPO, 16GA [THP13203S] one
Phoenix-10 Lite Speed Control: Brushless [CSEPHX10L] one
11x8 Slow Flyer Prop: Slow Stick [GWSEP1180] one
Laser 4 Micro 2-55 FM 72MHz [HRC156723] one ( comes with 2 hs-55 and one feather reciver )
Celectra 1-3 Cell LiPo Charger [EFLC3005] one
total
$427.52
thats not bad eh?
what do i need to make it?
i have a square, hot glue gun CA but i dont think its foam safe
total
$427.52
thats not bad eh?
Ok just to update .. pickec up a 370 BL with a e-flite controler, 4 hs-55's new prop, Charger, forgot the battery going to get a thunder power 1300mah 3 cell pack...
When i told the guy at the hobby shop today i wanted to do 3d he said with a 4 chan radio i had to use a Y harness for the front flaps and i cant move them independantly... humph... that cant be good can it? so he said to get a 5 or 6 chan radio and something computerized... yet again i keep hearing this. soooooo Anyone have a used one they wanna sell cheep or something? How about some recomendations for a inexpensive 6 chan computerized radio.......... I really wanted something for about $100 but it doesnt look like that is going to happen......................
My Feedback: (7)
i just recently bought a tribute and brushless set up himax 2812 out runner eflight 20 amp esp hitec laser 4 tx and flight pack with 3 hs81 servos. kinda heavy but the out runner does its job for now im saving to get some hs-55's and a gws rx ($20.00) on its first flight with the extra weight it still went vert and hovered till i back off into a chute. happy flyin
