Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
axi for gws zero????
Old 04-14-2005, 03:57 PM
Default axi for gws zero????
model axi motor for this plane? Thanzs!
Old 04-14-2005, 05:26 PM
My Feedback: (314)
Default RE: axi for gws zero????
How about a 2212/26 or a 2212/34? To mount either of these to the GWS stick mount, Top Creations R/C has a bracket that attaches to the motor.
Old 04-15-2005, 06:24 PM
What does the GWS Zero weigh?
Old 04-19-2005, 11:43 PM
FlybyPDX's Avatar
The bigger the better..... as long as you can still balance out your plane. I put the 2080/20 on my 2 Lb slow stick and its nice. You can never have too much power.... but your flight time goes down. Im geting about 15 min on a full pullon my 3s 2200.
Old 04-19-2005, 11:50 PM
FlybyPDX's Avatar
The bigger the better..... as long as you can still balance out your plane. I put the 2808/20 on my 2 Lb slow stick and its nice. You can never have too much power.... but your flight time goes down. Im geting about 15 min on a full pullon my 3s 2200.
I would get the 2212 20 or 26 turn depending on what prop you want to use.
http://www.hobby-lobby.com/brushless_axi.htm
Old 04-19-2005, 11:55 PM
FlybyPDX's Avatar
Ohyah... I also have carbon fiber wing and tail stableizers and a wood dowell through the 29" aluminum shaft. incase you were wondering how a SS can handle the Gs....
Old 04-26-2005, 03:59 PM
DRM
I think the axi 2212/26 is perfect for GWS warbirds, but the Zero tends to be tail-heavy & could use the extra weight of the axi 2808 series up front.
Old 04-26-2005, 04:16 PM
Very thanzs!
Old 05-05-2005, 01:24 PM
I'm using a 2208/34 with an APC 8-6SF prop TP 1320 11.1v and it is a fantastic combination. Much faster and smoother than the first one I had with the stock drive.
Old 05-06-2005, 07:15 AM
GWR
My Feedback: (31)
GWR's Avatar
I have the AXi 2208/34 on a GWS Beaver.Can never have enough Beaver.
Old 05-06-2005, 10:05 AM
drunkenbushman's Avatar
ORIGINAL: GWR
Never a truer word spoken
Old 05-06-2005, 10:09 AM
ORIGINAL: GWR
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
