Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
an old cox rtf
Old 01-08-2003, 02:45 AM
stag4u54
Default an old cox rtf
howdy all, i am trying to find out about an old cox r/c foam job...called "electric sundance".....needs a motor and gear assembly and it might just fly once more...given to me as junk and i wanna make it fly! need to know what i could use to power it.
Old 01-08-2003, 05:03 AM
jettstarblue
jettstarblue's Avatar
Default More info, please
Span, weight, dia. of motor opening, ect,? a speed 400 will most likely do it, keep us posted.
Jetts
Old 01-16-2003, 09:05 PM
WINANS
Default Electric Sundance
I bet you can get parts for that from Cox. Try the customer service number 800-525-7561 and ask for Ted Lewis, x314. Describe what youre after and ask him to dig around.
Old 01-20-2003, 02:39 AM
Derek_TX
If you are willing to modify a little, today's gear might be a metter bet that what was used in the past. Post the specs and specific suggestions mighe be generated. Wingspan & area, or chords, airframe weight, etc
The guess of a speed 400 will probably be on target, but use a geared prop, 2.5 to one or higher. There is a good chance the original specs were for a direct drive Mabuchi 540, close nuff to a speed 400, but gearing will work alot better.
