Jets
TX
Jets
Ok I am officially addicted to building. So I would like to make a delta wing or a jet I know there is the Mugi, but it seems to complicated. I really like the tiled plans.
So can you guys post links to anything that looks interesting.
Kevin
Kevin
MO
RE: Jets
Kevin,
I think the Nasty is more complicated than the mugi.
Give the mugi a chance, keep the foil thin and it will be plenty fast.
But if you really want some other jets, check out parkjets.com
Lots and lots of tiled plans.. All of them are much more complicated than the mugi though.
RE: Jets
go to 3dfoamy.com and check out the F-15 Park jet.... It was my first build... and was pretty easy. have to do a little sanding here and there and a lot of glueing but it can be done in a weekend if you got the build time...
