Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Projetti Motor
Old 04-03-2007, 01:45 PM
Default Projetti Motor
My bother in law got me a Projetti for Christmas. It is in the basement waiting to get built. Need suggestions for brushless motor setup. I WANT TO USE 3 cell 2100mah LIPO 20C. I am looking for some advice for a FAST PLANE!!!!!!!!!!!!!!!!!!!!!!
Old 04-16-2007, 01:33 PM
Default RE: Projetti Motor
Great plane, built for speed. Smooth leading edges, tapered trailing edges, flies like it is on rails! Currently my favorite one. I run mine with an E-Flite Series 6 2700Kv motor and an APC 4.75 x 5.5 prop. Unbelievable performance! 100+ MPH no doubt. Pulls around 25 amps on a 3cell 20C 2100 lipo. Fast, fast, fast!! You will not be disappointed with that power setup. I haven't got an official radar reading on it yet, but if it's not around 110+ mph straight and level, I'd be surprised.
Give yourself time to bleed off speed, it glides great under no power, but it just wants to keep going.
Old 04-16-2007, 01:54 PM
Thanks SPID. Will get this and get the thing running. I know it is a FAST plane as a friend had one but was using the 3300mah battery. What size esc and servo's are you using? Thanks.
Old 04-17-2007, 09:13 AM
I'm using an E-Flite 40amp ESC and (2) S75 servos (HS55 equiv.) The servos are performing very well. HS-65's (karbonite gears) would be an option as well if you are concerned about stripping the servo gears. But I haven't had any problems.
2100-2250Mah 3 cell 20C Lipo is really all you need and it saves you some weight. You'll still get plenty of WOT, knee knocking high speed flight. Good stuff!
ID:	666515   Click image for larger version
ID:	666516   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
