What wing for 3000kv motor
I have got a motor really cheap on ebay just need a wing to put it on now! what would be good with this high revving motor, here's the specs-
Specification
Max Current: 25 Amps
KV: 3000
Weight: 41.5g
Shaft Diameter: 3mm or 2.3mm (come with 2 shaft)
Mount Hole: standard 16.5
Motor size: ∮26mm, L 29mm
Input power: 2-3 Li-xxx
Suitable for Direct Drive (Prop. 4.75×4.5, 5.5×2.5, or 5.7×3), AirPower 3.88:1 (Prop. 11×47) GearBox with any aircraft under 750g.
The recommended speed controller is by using DearmFly-RC Melody 25A speed controller and AirPower Li-Po pack.
Specification
KV: 3000
Weight: 41.5g
OH
RE: What wing for 3000kv motor
Get you a apc 5x3 prop, a CC Pheniox 35 amp esc, a 2100/2500 20c 3 cell lipo and put it on a F-27 Stryker.
I have the Himax 2815-3000kv on one of mine and for a 3 cell setup it's a screamer.
I was thinking of getting a stryker because they look very cool, I have heard they are fairly draggy though?
OH
I can assure you with that kind of Kv and battery you wont notice, however what you hear about it being draggy is most likely from us in the stryker thread that push it to the limits.
It does have a thick chord which will have more drag than say a zagi, but you can always sand it down a bit and do some mods.
Go over and check out the Stryker way past the limits thread. Lots of good info and people over there.
OH
I can't answer that for you as I do not own a zagi or have ever flown one. But I am sure someone will give you an answer on that.
