Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
 Pushrod Tube for light foamies *help*??? >
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 10-13-2007, 07:13 PM
My Feedback: (8)
Default Pushrod Tube for light foamies *help*???
Any ideas on what could be used as a pushrod tube on light foam planes? I like to use light wire but as we all konw, it tends to flex when it is long in length. I am hoping to find something that can be picked up at a craft store, lowes, home depot, etc.
Old 10-13-2007, 10:52 PM
Default RE: Pushrod Tube for light foamies *help*???
kilmerelrc, I use bead seperators for beadwork crafts found in wal-mart crafts section ,comes in pack of ten. Thry are about 1/16'' in dia.
Spread them out about 4'' apart ,hold in place with foam-safe CA, be careful not to glue wire to guide!!! This works for foamies with push-
rods on the outside. glue guides to popcicle sticks and cut to fit in builtup fuses. Hope this helps you. Alan3dflyr
Old 10-15-2007, 09:31 PM
3DSAVAGE's Avatar
i use those little coffee stirrers, u know the ones that look like tiny straws? it works real well and they're cheap!
Old 10-15-2007, 11:15 PM
you can use the tubes out of cleaning fluid pump packs, also the plastic ink tube from Bic type pens
Old 10-16-2007, 07:39 PM
My Feedback: (8)
Great ideas, thanks
Old 10-17-2007, 04:04 PM
http://www.rcuniverse.com/forum/fb.asp?m=6184360
Old 10-17-2007, 09:47 PM
My Feedback: (8)
Ends of zip-ties..... excellent idea. I ended up using some cut off popsicle sticks with hole drilled in them but I will try the zip-tie next time.
Thanks all for the great suggestions
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
