bounce 3d?
FL
bounce 3d?
i just crashed an old plane and i want to build [link=http://www.flyelectric.ukgateway.net/bounce.htm]this[/link]. does it look like it would handle wind well?have any of u guys built one? can u give me a good motor size 4 it,and esc. and would a 1320mAh li po work for it?
RE: bounce 3d?
Check out Common Sense RC, they have this calculation think were you put in the specs of your plane and it tells you what prop, esc, motor and battery you can use.
I like the elevator on that plane,
