Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
Reload this Page >
How do I get a Bluebird 303 servo apart?
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 11-24-2007, 10:51 AM
expo
My Feedback: (20)
expo's Avatar
Default How do I get a Bluebird 303 servo apart?
I just bought an Ikarus foamie @ a swap meet and found it has 2 servos that don't work properly. I suspect it's the gears that are off tooth and may be stripped. I can't see how to get these apart to inspect them. There's no screws for disassembly!! Any help?
Old 11-24-2007, 04:29 PM
cheddar-caveman
Default RE: How do I get a Bluebird 303 servo apart?
I guess they are the same as the 306's. The casing splits around the body just under the fixing lugs.
Remove the labels from each side. Use a knife blade, or similar. Push it carefully into the case just under the securing lugs and twist. Do a bit each side until the horn arm bearing comes out of the top casing. Be careful as the top casing holds one end of each gear spindle and they all fall out!
Hope this helps.
