Go Back  RCU Forums > Electric Aircraft Universe > Foamies! - RC Electric Foam Aircraft
 What is the best paint for a foam GWS ? >
Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Old 11-30-2007, 09:20 PM
Default What is the best paint for a foam GWS ?
When painting an unpainted white foam gws, what paints have you found to be the best and what is your procedure for a great finish?
Thanks !!!!!!!
Old 11-30-2007, 10:18 PM
My Feedback: (10)
vicman's Avatar
Default RE: What is the best paint for a foam GWS ?
Wally world waterbased acrylic thinned with ...water and sprayed thru and airbrush.
Myriad of colors and you can get little bottles for $0.49 or bigger ones for a buck.
Old 12-01-2007, 12:39 PM
3DSAVAGE's Avatar
rustolem enamel paint is wat i used 4 my formosa. GREAT RESULTS! u can check my models 2 see 4 yourself
Old 12-01-2007, 09:46 PM
My Feedback: (10)
vicman's Avatar
Isn't the formosa EPP?
The GWS birds are styro and melt super easy. If you do try Rustoleum hold it back aways to allow some of the flash to burn off.
Old 12-02-2007, 10:30 AM
If you want spray can type, Short Cuts and H2O also work great. Available at craft and most hardware stores plus Walmart and most other dept. stores.
Bob
Old 12-02-2007, 11:03 AM
3DSAVAGE's Avatar
ORIGINAL: vicman
i have no idea if its epp. i thought it was the same as the other gws birds. to paint anything foam though, any water based, non achrilic paint will work
Old 12-02-2007, 01:02 PM
Would Parma Water Based Airbrush paint work? I've use it for my rc-bodies too, but would it work for painting GWS planes?
Old 12-08-2007, 12:12 PM
Try Krylon H2O. Doesn't melt fanfold, Depron, or Styrofoam. About $4.50/can at Wallyworld or Ace.
Old 12-28-2007, 02:08 PM
FERNDALE AIR FORCE's Avatar
I like the shortcuts paint.
Tim
Old 12-28-2007, 02:14 PM
My Feedback: (10)
vicman's Avatar
Short cuts is waaayyyy better than H20.
Just a bit spendy for goof around jobs.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
