Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
first foam plane.
Old 12-30-2007, 09:38 PM
Default first foam plane.
Ok, I have a sheet of blue insulation foam and need something to build with it. I was wondering if anyone had any plans of a high wing trainer type plane that i could use to practice while not at the field. Thanks.
Old 12-30-2007, 10:15 PM
calvino's Avatar
Default RE: first foam plane.
ORIGINAL: will in the 985
here is a link to some plans for a j3 cub, http://www.rcgroups.com/forums/showthread.php?t=245311
Old 12-31-2007, 05:15 PM
Do you have a set of comlete plans? All i can find is bits and pieces. I need them all in pdf format also.
Old 12-31-2007, 05:31 PM
calvino's Avatar
oh, sorry, if you poke around, I can find the page where they start, they are all in PDF format, sadly they are intersperced around[&o], why it is a good idea if you do a build log to have PLANS FIRST then make the log [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=7]start of plans[/link], [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=10]under carage wire[/link], [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=11]tail[/link], [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=12]windscreen[/link] [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=13]wing and fuse[/link] [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=15]cowl[/link] [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=20]aeleron wing, contd on next page[/link] [link=http://www.rcgroups.com/forums/showthread.php?t=245311&page=21]wing forming template[/link] hope that helps the plans are on those pages, so a little scroling should help, as well as the fact that they show how the stuff should go together[8D]
Old 12-31-2007, 05:54 PM
thanks, it's between this and a stc.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
