GWS Aircraft
Where can I find soem of the thin foam that make up the tail feathers on the GWS pico Tiger Moth.
I think it is about 1/4 inch thick, maybe even less than that, I know I can get replacement parts, but if I could by a sheet of foam that would be better. Weskel |
RE: GWS Aircraft
I have a couple of these, on one of them I used balsa for a tail feather repair job, flys as good as new now.
RE: GWS Aircraft
Thats what I was thinking about using, did you just use clear packing tape for the hinges, that was my plan...
weskel |
RE: GWS Aircraft
Hey weskel,
Yeah, I just taped the hinges, you should go to a sport store, in the hockey section they have clear tape they use to tape there laces up with. Its the perfect size and works much better, stretches great. |
RE: GWS Aircraft
Hello,
If you have a Dairy Queen outlet you can get the Depron from them. They use it as a flat plate for the ice cream cakes. Heck, they gave me a stack when I asked. Try it out... Foamio |
