Blue Foam Delta +
1 Attachment(s)
Specs: motor: GWS EPS 300C
prop: 11-8 ws: 31" length: 30" auw: 16.4 oz. thrust: measured 14 oz. battery: 1000MaH NiMH 8 cell Jeti 050 speed control servos: cs-21 bb deans mini whip ant. Hitec 555 Arrow shaft spar |
Blue Foam Delta +
Looks good, is it your own design? Do you have plans with more specs>
Woodduck |
Blue Foam Delta +
Check out this link for Blue Delta info:
http://www.rcgroups.com/forums/showt...threadid=66717 and this one http://www.rcgroups.com/forums/showt...threadid=79273 Chuck |
