plane works without antenna soldered on why?
I took apart my mini storm launcher and going to put it on another foamy I'm building.
took the antenna and am going to solder longer one on, but i can it without in on and the props still run like the antenna was still on how can that be? I'm sure the range won;t be that great but it's weird how it works with it off. PS I'm going to put a longer one on it so i have a range of about 600ft now. |
RE: plane works without antenna soldered on why?
longer antennas do not increase range.........
ORIGINAL: exeter_acres longer antennas do not increase range......... well reception then |
there is an optimum antennae length for each receiver and going either longer or shorter will gradually decrease the range or reception capability.
To a point, but longer gets better at some point. The issue is that the antenna needs to be a length that corresponds to a wavelength of the frequency in question. IE, if your antenna is 1/4 wave, a little longer will be de-tuned, and be bad, but twice as long (half wave) will give a better signal . . . should be by about 3db (double the signal . . .) and so forth as you get longer.
Unfortunately, you can't tow two miles of wire, or we would have insane range . . . . - Tim ORIGINAL: Gulliver there is an optimum antennae length for each receiver and going either longer or shorter will gradually decrease the range or reception capability. |
Fly it with the same length antenna ..........ONLY. Best protection against glitches & motor noises. Some transmitters and receivers can be damaged if the antenna is not used. Rich |
ORIGINAL: tadawson To a point, but longer gets better at some point. The issue is that the antenna needs to be a length that corresponds to a wavelength of the frequency in question. IE, if your antenna is 1/4 wave, a little longer will be de-tuned, and be bad, but twice as long (half wave) will give a better signal . . . should be by about 3db (double the signal . . .) and so forth as you get longer. Unfortunately, you can't tow two miles of wire, or we would have insane range . . . . - Tim ORIGINAL: Gulliver there is an optimum antennae length for each receiver and going either longer or shorter will gradually decrease the range or reception capability. that's what i did it's twice as long |
Good point. I didn't think of that.
I am told however that some receivers have built in base loading which makes the lengths hard to figure out. |
