Go Back  RCU Forums > RC Universe Support > Forum questions or problems
 ON GOING POSTING PROBLEM >
Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
Old 09-02-2009 | 03:52 PM
Default ON GOING POSTING PROBLEM
HI i need to make you aware of a problemi write my postthen preview my post -all looks fine when the post goes on to the web site the words are bunched together on top of each other and difficult to read and understand because of something that is causing that to happenthis has been happening for a long timei just got to writting it up nowif you need an examplego to -Airplanes-crash and rebuild-( my post-)-a crash experiencethose are my last few posts and you will see the problem there thank you TONY0707 (my screen name ) any help is greatly appreciated
Old 09-02-2009 | 04:30 PM
My Feedback: (325)
Default RE: ON GOING POSTING PROBLEM
HI i need to make you aware of a problem i write my post then preview my post -all looks fine when the post goes on to the web site the words are bunched together on top of each other and difficult to read and understand because of something that is causing that to happen this has been happening for a long time i just got to writting it up now if you need an example go to -Airplanes-crash and rebuild-( my post-)-a crash experience those are my last few posts and you will see the problem there thank you TONY0707 (my screen name ) any help is greatly appreciated
Tony I see about 6 missing spaces and punctuation on your last posts. Is this what you talk about? The text above I added the spaces , but not the punctuation. How does it look?
Old 09-03-2009 | 08:49 AM
HI YES -it is the spacing that is the problemthe spacing is correct when written and at the preview-but words get bunched up and run into one another-when the preview gets posted to the web sitethanks for your help with this REGARDS TONY
Old 09-03-2009 | 04:42 PM
My Feedback: (325)
That is strange, I am sorry I can't help other than to confirm that I too see the words bunched together on your posts. (it looks like me when in a hurry)
It may take someone from rcu here to check it out. In the meantime how about editing some posts and adding some spaces to see if it works.
There are a dozen spaces between my last 8 words (above), but they do not show up. So much for my test. I'm not much of an editor. [sm=thumbs_down.gif]
Old 09-03-2009 | 06:43 PM
HI GUVER glad you see the problem not sure what you mean by edit some posts and ad spaces -am i the only one having this problem- ?-my problem started months agojust got inspired to get it corrected nowwill you be having someone at RCU -get to the bottom of this ? thanks TONY
Old 09-03-2009 | 06:45 PM
HI GUVER-as you can see ever time i post -there a words jammed togetheri am not doing thaton my end.
