Issue with the Blog editor
I hadn't updated my blog in quite a while, and I went to finally make a new post earlier this evening. When I submitted the blog post, none of my line returns showed up and my post was all one big run-on paragraph. I tried adding a second {enter} between paragraphs, but it all just got run together.
What do I have to do to separate paragraphs in the blog editor? I am using IE 11 as a browser. I also tried submitting it using Opera v 23.0, but experienced the same result. |
To format your text, including using carriage returns, you must use HTML tags. To separate comments in a single entry you have a couple of options. <br><br> will start a new paragraph as will <p>
I've asked our IT staff to take a look into supporting these functions without resorting to HTML tags but it may take some time before this is implemented. |
| All times are GMT -8. The time now is 11:24 AM. |
