problem posting pics
i can upload the pics, but then what am i supposed to do?
i dont see anything to click on to find the pics i uploaded |
RE: problem posting pics
Once you select a file from your computer, you should see a box that says "upload in progress". Once the image has uploaded to RCU it will tell you file uploaded successfully and ask you to click OK.
Another possibility is if you are previewing your message prior to posting. This will remove the uploaded picture, so don't review the message before submitting. NOTE: These instructions assume you are uploading your images to a discussion post and not somewhere else on RCU. |
after the upload too you must submit the post itself with some text in it or the post and photo won't insert
ahhh...thats the problem then...there has to be text in the post...i thought you could just post pics with no text
| All times are GMT -8. The time now is 08:12 PM. |
