Need to increase the system memory on server
I keep on getting SQL errors saying that there's not enough system memory to process the request.
It should show in the logs. |
RE: Need to increase the system memory on server
The error I keep getting.....
Microsoft OLE DB Provider for SQL Server error '80040e14' There is insufficient system memory to run this query. /forum/tt.asp, line 377 |
it was a sql bug actually. A simple restart fixed it. we are looking into whether a patch will fix it from occuring again. thanks for heads up
Time for another reboot then I guess. Can't get into half the forums and when I do it will bomb out eventually with the memory error. It is 11:30 AM CST. This is one of teh few forums I could get into.
Me too
2:51 PM Atlantic time |
fixed earlier today. we had a drive crash in our RAID array so we were rebuilding it which was causing some quirks earlier today. things should be ok now. if not let us know so we can investigate further!
| All times are GMT -8. The time now is 10:21 PM. |
