To the Moderators
First, I want to thank you for including a spell checker - I do use it.
However, there are a bunch of words I feel that you need to add to it. The ones that come to mind are: Hitec, Futaba, Monokote, Airtronics, Trax I'm sure you'll get a lot more suggestions. Thanks, KW_Counter |
RE: To the Moderators
ORIGINAL: KW_Counter First, I want to thank you for including a spell checker - I do use it. However, there are a bunch of words I feel that you need to add to it. The ones that come to mind are: Hitec, Futaba, Monokote, Airtronics, Trax I'm sure you'll get a lot more suggestions. Thanks, KW_Counter |
:D:D:D
Don't feel bad, "RCU" isn't in there either :D
Unfortunately, we mods have no control over the Spell Checker |
Minn,
Who does have control over it? Can this suggestion be sent up the ladder? Thanks, KW_Counter |
Here's a thought: How about making the "Insert in Document" button work? The button itself says "(disabled temporarily)". It seems that "temporarily" must mean year after year as this is how long it has been disabled.
I mean really, what's up with that? |
When the forum changed software a few years ago it caused a glitch with the insert part of the spell check that the administrators decided was more trouble than it was worth to fix. At the time RCadmin recommended IE Spell Checking, which is a free download. http://www.iespell.com/download.php I have been using it for over two years with no problem and it is much better than the spell checker included in the forum. It allows the individual user to add words.
The Google tool bar also has a spell check. |
Can you raed tihs? Olny srmat poelpe can.I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg.The phaonmneal pweor of the hmuan mnid, aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae. The rset can be a taotl mses and you can sitll raed it wouthit a porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe. Amzanig huh? yaeh and I awlyas tghuhot slpeling was ipmorantt! just kidding
| All times are GMT -8. The time now is 09:33 PM. |
