RCU Forums
-   Forum questions or problems (https://www.rcuniverse.com/forum/forum-questions-problems-239/)
-   -   JAVA script error (https://www.rcuniverse.com/forum/forum-questions-problems-239/4771398-java-script-error.html)
bluemagic98 09-20-2006 11:29 AM
JAVA script error
1 Attachment(s)
HI
the last 2 or 3 days ive been getting this java error popup whenever I reload a page in the forums. Thought I would let you know Ive attached a screen shot of the error:
bluemagic98 09-21-2006 02:32 PM
RE: JAVA script error
Am I the only one having this issue?
bluemagic98 09-22-2006 01:03 AM
checked and unchecked everything about java in the advanced tab under internet options as well as upgraded to internet explorer 7 still get these errors whenever i open a page within the forums. Is there anyone getting this?
Nathan 09-22-2006 12:46 PM
Try to log out, clear all your cookies and cache and log back in. If it continues let us know.
bluemagic98 09-22-2006 08:35 PM
sorry it still has this error deleted everything unless i need to manually go in and delete stuff but i got cookies temps history's and form Data Im rather stumped.
mvigod 09-24-2006 09:22 PM
is this on page loads or reloads? also every single page or just some?
bluemagic98 09-24-2006 10:33 PM
load reload reply all forum pages. Im pretty much clueless as to whats up with this.
even on the all forums page
I even log out and i get the error makin me buggyer than I already am
bluemagic98 09-29-2006 02:12 AM
guess im not going to fix this
bluemagic98 10-02-2006 05:52 AM
bump
mvigod 10-03-2006 09:05 AM
what operating system and browser and version are you using?
bluemagic98 10-03-2006 11:15 AM
windows xp sp2 fresh install had explorer vertion 6 upgraded to vertion 7 still doing it when I setup new e-mail I had to delete cookies and passwords thats when it started an earlyer post asked me to sign out and delete cookies log back in and it still does this.
I ran spy bot it came up empty
bluemagic98 10-08-2006 05:48 PM
bump someone here has to have some idea what causes this?
mvigod 10-08-2006 10:03 PM
do you have any firewall software like norton, zone alarm or other?
bluemagic98 10-08-2006 10:07 PM
yes i have sygate and ive tried disabling it. however i havent tried deleting the cookies and logging out and back in while it was disabled. But what troubles me is ive ussed sygate for many tears and it was never a problem.
bluemagic98 10-08-2006 10:12 PM
1 Attachment(s)
I just tried the logout and deleted all cookies and temps and histories the works loged back in with the firewall disabled and still get the same error. if i refresh this page the line # is 2861
mvigod 10-09-2006 10:06 AM
this is very odd. we have no other reports of errors like this and we have not changed any code in months on our thread view pages here. I wonder if some other service or software on your system is blocking certain code which makes javascript think a particular object does not exist.
you could go into your options and turn off javascript warnings just so you don't have to deal with the popup which would solve the annoyance factor for now
bluemagic98 10-16-2006 01:16 PM
somehow the last post you made was not forwarded to my e-mail but ive removed all the java warnings and had no luck removing the popup. the watt flyer forum has no issues or any other forums i go to I will try another computer on my network to see if its the ISP we did get a new provider about the same time as this issue came up. sorry it took so long to reply as i was not sent a e-mail notification on your last post
bluemagic98 10-20-2006 01:54 PM
ive logged in on another machine using xp with explorer vertion#6 not 7 as is with my machine it has the same sygate fire walland there is no error with this machine. Ive about run out of things to try other than reinstalling my OS and that ide like to avoid if posable. I did reinstall explorer vertion 7 and reset all the settings as well as checked and unchecked every java active x thing i could find I know this started when i was ussing vertion 6 so the problem followed me. I had to make explorer forget the logins and passwords to gain acces to my e-mail and this started. Still stumped Iff I find it ill be sure and get back to you on it. If you have any ideas let me know. Thank you
bnrusso 11-02-2006 02:44 AM
I too have been getting java script errors every time I go to a forum page.
I copied the error to a word file but I don't see a way to post it.
This error is from refreshing THIS page:
says: description object expected
http://www.rcuniverse.com/forum/m_47.../anchor/tm.htm
Line 3234
see more details? OK CANCEL
You must click on OK or CANCEL to make the error box go away.
bnrusso 11-02-2006 02:53 AM
FYI: I am using SUN Java JRE 1.5.0_06
bnrusso 11-02-2006 03:06 AM
I have no firewall software, just NAT DSL router firewall and MICROSOFT XP build in internet firewall.
I tried turning off SUN java and just use microsoft java and that did not stop the error.
I did clear cookies and history too, didn't work there either.
bluemagic98 11-02-2006 04:34 AM
I you gave me an idea however it didnt help
I installed Java Runtime Vendor: Sun Microsystems Inc. Java Runtime Version 1.5.0_09
I wish it had but no joy this has been a long time thing I did download Firefox
http://www.mozilla.com/en-US/ and that worked fine no errors so it is definetly within explorer.
mvigod 11-02-2006 12:42 PM
Is this IE7 or IE6?
also this has nothing to do with JAVA. Javascript is a browser based scripting language and unrelated to JAVA despite their similar monikers.
mvigod 11-02-2006 12:43 PM
On IE6 you might try this
got to Tools > Internet Options > Advanced
then check off disable script debugging checkbox
bnrusso 11-02-2006 12:50 PM
ORIGINAL: RCadmin
Yes it is IE6
Yes it goes away when I take the check off from "disable script debugging (Internet Explorer)"
Thanks.
That makes the error go away.
mvigod 11-02-2006 11:50 PM
good..you don't need that on anyway unless you are a developer
bluemagic98 11-03-2006 03:06 AM
LOL well ive had this on IE6 and ive upgradded to IE7 and ive checked and unchecked everything I can and it wont go away disable script debugging is checked.
bnrusso 11-03-2006 12:10 PM
It should be UNCHECKED.
I know it sounds stupid but uncheck the box
mvigod 11-03-2006 02:52 PM
We have not tested IE7 yet as it had blown up our systems and we uninstalled it awhile ago. there is possibility some issues may exist with IE7 if their js engine has been rewritten
bluemagic98 11-03-2006 04:15 PM
I have checked and un checked and removed IE7 gone back to IE 6 deleted all my cookies and reset all my passwords and checked and unchecked all things related to this no luck. reinstalled IE7 and unchecked and rechecked all the checks i could find still no luck. I dont see me getting to the bottom of this.
RBardin 11-03-2006 06:24 PM
I don't know if this is related, but I have been getting JS errors for months - here are the conditions:
1. Only when viewing classifieds - any classifieds.
2. Only when NOT logged in - I never log in unless I intend to post or PM, and my browser clears all cookies automatically when closed, anyway. Log In! might be the simple answer, but I don't like to or want to unless I need to.
3. I use Avant, but it does it in IE6 as well, regardless of OS - I run several windows based OS's - Win2K Pro, XP, XP Pro and media center - no difference in behavior with different OS.
4. The error only comes up when after viewing an ad and hitting the back button to return to the listings.
5. It does it every single time I back out of any ad unless I'm logged in.
Heres the Message text:
Description: Function expected
Source:http://www.rcuniverse.com/market/category.cfm?catID=12
Line 766
See more details? (with OK or Cancel buttons)
This is the only web board that this happens on, and I frequest MANY!! and not just R/C, either. It would be great if someone could look into this and fix it, or offer a setting suggestion to help. I tried unchecking disable script debugging - it didn't help. I think there are some errors in your code, Marc![:-]
bnrusso 11-03-2006 07:51 PM
the instructions they gave me to take the check off the boxes made the problem go away AFTER I shut the browser down, and restarted. I have not seen that error since.
bluemagic98 09-11-2007 11:55 AM
not sure what changes where made here but this issue has been corrected through no action of mine. My guess is there was a programming issue here as 3 of my computers where doing this and not all at the same time but now none of them are. Could it me a microsoft update issue? who knows just glad its gone.
