Bugged search tool
Hello,
I think the search tool is bugged. Example : Search "RCM AND Eagle" with the Advanced search checkbox checked, and other options left as default, it won't yield any result, though there is at least this match : http://www.rcuniverse.com/forum/m_24...y_EAGLE/tm.htm It is not because there are too many matches (check subject only if you wish)... I had already seen some strange behaviour but never nailed it. It's sometimes more efficient to use google instead of the search tool, but sometimes not enough [:o] Could you please fix it ? Such a feature is one of the most important ones in any forum ! Regards |
RE: Bugged search tool
try this: http://www.rcuniverse.com/forum/sear...mitbutton=+OK+
or use the google seach at the top of the forum search page too which yields results: http://www.rcuniverse.com/googleresu...RID%3A11&hl=en |
Nailed it :) !
rcm AND eagle won't yield any result rcm and eagle yield good results So a fix of the hint may be the way to go :) Advanced Search (use AND, OR, NOT to construct search phrase) -> Advanced Search (use and, or, not to construct search phrase) |
superb find. I have changed the hint to lowercase. wish I knew this 2 years ago! thx
| All times are GMT -8. The time now is 12:48 AM. |
