AHH! Java Script Errors!
This has been an ongoing problem for two weeks now and I'm getting extremely annoyed by it.
While browsing this board, I get a Java script error box on EVERY page that I open. It always says "Java script error, Object expected, Line xxx", in which the line number is always different. Can someone please tell me how to stop this or why it is happening? Thanks! |
RE: AHH! Java Script Errors!
The first thing I would suggest is to make sure your browser is current and up to date with Java software. The second thing to try is logout, clear all your cookies and cache then give it a try again. It's possible your session has been corrupted and needs a refresh.
You can also disable debugging and error messages for your browser. unless you are a developer you really don't need it on. there may be something with your browser or config causing this as a normal IE6, IE6, firefox install on any newer OS won't toss this type of error
| All times are GMT -8. The time now is 07:38 PM. |
