RCU Forums
-   Forum questions or problems (https://www.rcuniverse.com/forum/forum-questions-problems-239/)
-   -   Ouote problem (https://www.rcuniverse.com/forum/forum-questions-problems-239/5937759-ouote-problem.html)
MinnFlyer 06-03-2007 08:04 AM
Ouote problem
I have noticed that when you quote someone, after the "Closed Quote" code, the word "undefined" appears
mvigod 06-03-2007 09:35 AM
RE: Ouote problem
already aware and working on it..fix will soon be in place.
mvigod 06-03-2007 12:47 PM
RE: Ouote problem
ORIGINAL: RCadmin
fixed! all tags should be working correctly now
hands without shadows 06-03-2007 02:04 PM
RE: Ouote problem
Im still having the problem.
mvigod 06-03-2007 02:14 PM
RE: Ouote problem
ORIGINAL: hands without shadows
clear you cache, close all browser windows and reopen. you have an old javascript file in your cache. until you clear it the problem will persist although in 24 hours your browser should try to grab latest regardless and that would solve too
tippy 06-03-2007 04:46 PM
RE: Ouote problem
ORIGINAL: RCadmin
ORIGINAL: RCadmin
Sorry ... it's not fixed!!!!
Try hi-liting (selecting) any of the text you see in a quote or any text you type yourself ...
Can you select anything??? I can only select one maybe two characters at a time ...
Also this affects creating a link. Prior to this problem ... I could hi-lite (select) a word and press the link button and the hi-lited text woud appear in the URL name textbox. It no longer does this ... I now have to enter the thread name manually.
You're not done with the "fixin" yet ...
Oh ... if only "fixin" the bug was as quick as installing the bug ...
mvigod 06-03-2007 07:05 PM
RE: Ouote problem
sounds like you have old files in your cache..clear your browser cache, close all browser windows and restart then try with full reload and report back. I have testd in IE7 and Firefox and all works fine and so have others verified
piper_chuck 06-03-2007 08:34 PM
RE: Ouote problem
I still had the problem with Firefox. All I had to do is clear the cache and reload the page. All is well now...
mvigod 06-03-2007 09:36 PM
RE: Ouote problem
I think anyone that has problems now is just old cache issue and they just need to clear it and reboot browser. Alternately if they wait a day or so the cache will self clear
tippy 06-04-2007 05:41 PM
RE: Ouote problem
ORIGINAL: RCadmin
Using IE6, I've cleared cache and have waited a day and the hi-lite (selecting text) problem is still there.
Sorry ... but can't seem to make it work like it did before you upbugged ... oops I'm mean upgraded.
tippy 06-05-2007 06:54 PM
RE: Ouote problem
The hilite (selection) of text doesn't work if I choose <reply> either.
I've flushed and flushed and this probelm just won't go down ...
IE6
mvigod 06-05-2007 08:23 PM
RE: Ouote problem
anyone else have this error on IE6? I only have IE7 and cannot test to see if this is global or isolated
tippy 06-08-2007 05:59 AM
RE: Ouote problem
ORIGINAL: RCadmin
Reference the thread "[link=http://www.rcuniverse.com/forum/m_5952604/tm.htm]highlighting problem[/link].
They appear to be having the same problem.
Since the "highlighting problem" is more appropriate to the problem I'm having, I'll continue my responses in that thread.
