RCU Forums
-   Forum questions or problems (https://www.rcuniverse.com/forum/forum-questions-problems-239/)
-   -   Cold Fusion Email Server Setup Errors!! (https://www.rcuniverse.com/forum/forum-questions-problems-239/6234213-cold-fusion-email-server-setup-errors.html)
Bill Killillay 08-13-2007 06:28 PM
Hello, while working in the market area of your site I've run into this error message in several areas. While submitting an offer on an item, while trying to remove one duplicate offer because of said error and while trying to report said error I got the same error.
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
An exception occurred when setting up mail server parameters.
This exception was caused by: coldfusion.mail.MailSessionException: An exception occurred when setting up mail server parameters..
The error occurred in D:\rcu\signup\trouble.cfm: line 86
Called from D:\rcu\signup\trouble.cfm: line 86
84 : ------------------------------------------------------
85 :
86 : Manage: http://www.rcuniverse.com/marshal/tr...ostid=#get.id#
87 :
88 : View All: http://www.rcuniverse.com/marshal/troubleq.cfm
Resources:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.0.04506; .NET CLR 1.1.4322)
Remote Address 65.12.164.87
Referrer http://www.rcuniverse.com/signup/trouble.cfm
Date/Time 13-Aug-07 07:24 PM
Stack Trace (click to expand)
at cftrouble2ecfm213302908.runPage(D:\rcu\signup\trou ble.cfm:86) at cftrouble2ecfm213302908.runPage(D:\rcu\signup\trou ble.cfm:86) at cftrouble2ecfm213302908.runPage(D:\rcu\signup\trou ble.cfm:86)
coldfusion.mail.MailSpooler$SpoolLockTimeoutExcept ion: A timeout occurred while waiting for the lock on the mail spool directory.
at coldfusion.mail.MailSpooler.postSpoolMail(MailSpoo ler.java:1189)
at coldfusion.mail.MailSpooler.storeMail(MailSpooler. java:652)
at coldfusion.tagext.net.MailTag.doAfterBody(MailTag. java:619)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java :152)
at coldfusion.tagext.lang.IncludeTag.doStartTag(Inclu deTag.java:349)
at coldfusion.filter.CfincludeFilter.invoke(Cfinclude Filter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(Applica tionFilter.java:225)
at coldfusion.filter.RequestMonitorFilter.invoke(Requ estMonitorFilter.java:51)
at coldfusion.filter.PathFilter.invoke(PathFilter.jav a:86)
at coldfusion.filter.ExceptionFilter.invoke(Exception Filter.java:69)
at coldfusion.filter.ClientScopePersistenceFilter.inv oke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilt er.java:38)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilt er.java:38)
at coldfusion.filter.DatasourceFilter.invoke(Datasour ceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(Req uestThrottleFilter.java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at coldfusion.bootstrap.BootstrapServlet.service(Boot strapServlet.java:78)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker. java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvok erChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequ estDispatcher.java:257)
at jrun.servlet.ServletEngineService.dispatch(Servlet EngineService.java:541)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable( JRunProxyService.java:204)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invok eRunnable(ThreadPool.java:318)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRu nnable(ThreadPool.java:426)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeR unnable(ThreadPool.java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java :66)
mvigod 08-14-2007 10:17 PM
RE: Cold Fusion Email Server Setup Errors!!
next time you get any error scroll to the bottom of page and note what server you are on (rcu1, 2, 3 or 4) and let us know. this helps alot. these issues are usually isolated to the one front end server you are on
marc
Bill Killillay 08-15-2007 05:37 AM
ORIGINAL: RCadmin
marc
Sure thing, will do.
