can't post pics!
I have posted hundreds of pics here, and I do the same thing to them every time when saving them. I had no trouble posting them to another website forum, so I know it's not on my end. They are in jpc format and about 200kb each. When I select them and click "upload", I get "Request object error 'ASP 0104 : 80004005'
Operation not Allowed /forum/js/PGDUpload.asp, line 169 " What gives??????????????? |
RE: can't post pics!
1 Attachment(s)
Just tryed it to this post/thread..
Says pics went thru... Robby |
is the image post issue still here? if it happens again click RC Community button on top of any page and scroll to bottom. there you will see RCU1,2,3,4 or 5. lmk which server are you on which is causing the issue and also what browser/os you use. I can then debug. I suspect it is our new server and a permission issue but need to verify the server you are on to make sure
marc |
I'm getting the following errors and I also tried to upload to this thread, an airplane thread, and a car thread. This includes the attempt to upload a single file with a file size of 257K. I've also tried logging off, deleting all temp files, and then logging in case the system tries to and/or does log me onto a different server.
http://www.rcuniverse.com/forum/uplo...de=&messageid= HTTP 500 Internal Server Error |
I'm getting the exact same message, I'm on RCU5. Turned off All of Norton too. Any ideas?
It's happening again today on RCU4!
same error
Request object error 'ASP 0104 : 80004005' Operation not Allowed /forum/js/PGDUpload.asp, line 169 |
ORIGINAL: nick2618 same error Request object error 'ASP 0104 : 80004005' Operation not Allowed /forum/js/PGDUpload.asp, line 169 |
The latest message . . . when I tried to Log Out.
The web site you are accessing has experienced an unexpected error. Please contact the website administrator. The following information is meant for the website developer for debugging purposes. Error Occurred While Processing Request Session is invalid Resources: Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option. Check the ColdFusion documentation to verify that you are using the correct syntax. Search the Knowledge Base to find a solution to your problem. Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727) Remote Address [REMOVED] Referrer http://www.rcuniverse.com/forum/m_5213583/tm.htm Date/Time 25-Sep-07 09:56 PM |
TnB what server are you on?
also to others are the image upload issues resolved now? if anyone has issue please click community button on top nav then scroll to bottom of page and note which server you are on. I need to know which one rcu1 to rcu5 to troubleshoot which of our 5 servers is balking |
Currently, I'm on RCU3.
However, I am on a different computer from a different location now. And, it let me log out this time. |
Mine is working now. :D
Im Currently on RCU5 and having the same problem! I tried using both IE7 and Firefox, not avail!
Ditto RCU5.
I had giant thumbs this afternoon.. now I can't post pics at all.. Same error as the first poster..
I'm using Firefox 2.0.0.7 I also tried IE 7.. same issue RCU5 I can upload to my gallery without any issues.. normal thumbs and all. |
I can't post either, but I will have to check which server I am on tonite. I am getting the message "page can't be displayed".
I am unable to post pics within the Twin/Multi engine forum. I get a message say the page not found. At the bottom of the window, it shows an internal server error.
The following number is related to my problem... 0.188RCU1 Mike |
cant post pics again...
Firefox 1.0.5.12 & ie 7.0.5730.11 On RCU 5 on both. |
rebooting 1 and 5 now..please test in 10 minutes
Still unable to upload pics to the twin/multi engine forum
Code: .406RCU1 Mike |
Its working now THANK YOU! :D
what server were you on when you tested? same as last time or different one?
ORIGINAL: UkerDuker Still unable to upload pics to the twin/multi engine forum Code: .406RCU1 Mike what error are you getting? also what browser and OS are you on? |
I am using IE 6.0 and windows XP Pro.
I can select the pics from my HD, but when I click OK, I get the following message: The page cannot be displayed There is a problem with the page you are trying to reach and it cannot be displayed. -------------------------------------------------------------------------------- Please try the following: Open the www.rcuniverse.com home page, and then look for links to the information you want. Click the Refresh button, or try again later. Click Search to look for information on the Internet. You can also see a list of related sites. HTTP 500 - Internal server error Internet Explorer Mike |
OK, I was able to successfully upload a pic again. THanks!
Mike |
| All times are GMT -8. The time now is 11:07 AM. |
