Subscription Notification
Hello, I would like to report that I am getting this message when ever I open a message labeled named "Subscription Notification,"
but I don't get it when I open a message named "RCU forum subscriptions". Server Error in '/forum' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL: 1. Add a "Debug=true" directive at the top of the file that generated the error. Example: <%@ Page Language="C#" Debug="true" %> or: 2) Add the following section to the configuration file of your application: <configuration> <system.web> <compilation debug="true"/> </system.web> </configuration> Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode. Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario. Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] ASPPG.BaseClasses.CommonPageBaseClass.DisplayPermi ssionErrorInterface(CommonMasterPageBaseClass master, String errorMessage, Boolean displayLoginInterface) +107 BoardDown.Page_Init(Object sender, EventArgs e) +291 System.Web.UI.Control.OnInit(EventArgs e) +99 System.Web.UI.Page.OnInit(EventArgs e) +9 System.Web.UI.Control.InitRecursive(Control namingContainer) +321 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +834 Version Information: Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433 I just though I would let you guys know. Thanks Warheadforever |
RE: Subscription Notification
This was sent out by the system after we pushed the new upgrade out last friday. Be since we have pulled the upgrade back down the link that notification will not work. You can disregard the notification. You should still get notifications on the thread in the old (current) system without any issues.
Ken |
O.K. thanks, and yes the old system links work perfectly.
| All times are GMT -8. The time now is 07:02 PM. |
