RCU Forums
-   Forum questions or problems (https://www.rcuniverse.com/forum/forum-questions-problems-239/)
-   -   Error msg - subject box (https://www.rcuniverse.com/forum/forum-questions-problems-239/8781204-error-msg-subject-box.html)
Edwin 05-19-2009 07:46 AM
Mark,
Twice this morning Igot an error msg stating (something to the effect) that I had not entered anything into the subject msg box (may not be exact msg) but there was text in the box. Hit ok the second time and it worked. Clear as mud?
Edwin
Got it again. This was the error msg. It had text in both already.
"Please enter something into body and subject box"
Edwin
mvigod 05-19-2009 10:09 AM
RE: Error msg - subject box
test
mvigod 05-19-2009 10:10 AM
edwin,
try clearing your browser cache. I think this problem was fixed and you might have some old javascript code in your browser cache<br type="_moz"/>
Edwin 05-19-2009 01:45 PM
Will do!</p>
Edwin</p>
mvigod 05-19-2009 09:34 PM
Let me know if it worked
Edwin 05-19-2009 09:45 PM
So far its good.  By end of tomorrow should confirm it.</p>
</p>
Oops, did it again on this msg.  It always works on the second attempt.</p>
Edwin</p>
Edwin 05-20-2009 07:50 AM
Test</p>
</p>
Edwin 05-20-2009 07:53 AM
Test</p>
</p>
Edwin 05-20-2009 07:56 AM
FYI - The last two tests were on my home computer running XP.  Seems to be no problem.  The other msgs are normally run on my work laptop running Vista.  I have no control over the s/w setup on the laptop.  The company IT dept manages that.  Seems like it worked one or two times right after I deleted all the temp files, then it came back.</p>
Edwin</p>
