Mini-Review KC02 5ghz Transmitter and Camera
5 Attachment(s)
Hello,
Some days ago i got the KC02 Vtx and camera combo from akktek.com: http://www.akktek.com/products/micro.../akk-kc02.html The hardware costs about €30 https://static.rcgroups.net/forums/a...g?d=1505012153 https://static.rcgroups.net/forums/a...g?d=1505015102 https://static.rcgroups.net/forums/a...g?d=1505015103 Here are some details: 7-20V FPV Transmitter Video Format: NTSC, Output Impedance: 50 Ohm Antenna connector: RP-SMA connector Supply current: 280 mA, Operating Temperature: -10 +85℃ Video Band Width: 0-8.0 MHz, Audio carrier Frequency: 6.5 MHz Video Input Level: 0.8,1.0,1.2 Vp-p, Video Input Impedance: 75 Ohm Audio Input Level: 0.5,2.0 Vp-p, Audio Input Impedance: 10K Ohm Operating Voltage: 7-20 V, VTX Size: 31mm*25mm*8mm 600TVL perfect picture quality camera CCD: 1/3” Sony SUPER HAD II CCD Pixel: NTSC: 768(H)×494(V),TV System: NTSC Resolution: 650TVL(b/w), 600tvl(color) Synchronization : internal synchronize Shutter Speed: (CCD IRIS) NTSC: 1/60~1/100000 sec Noise: > 60 (AGC OFF), Video Out: 75ohm, synchronize Min. Illumination: 0.01Lux, Auto Gain: Off/Low/Mid/High Back Light Compensation (BLC): Off /Back light compensation/ Strong light suppression Private shading (PRIVACY): 1~8 private shading area Motion Detection (MD): On/ Off (Multi level sensitivity settable) Auto White Balance: Manual / Auto / Auto track Mirror: Horizontal Mirror optional Negative: Positive / Negative optional Color to B&W: Auto, DNR: 2DNR; WDR: D-WDR Day / Night Shift: Auto/ Color/ B&W Menu (OSD): English menu, White Dot Repair: Support Image Adjustment: Support, Camera Title: Support Power Requirement: DC5V~22V, Working Humidity: 20~80% Storage Temperature: -40 ℃ ~ +60 ℃ Storage Humidity: 20~95% Dimensions(mm): 25X25(W*L) Power Consumption: 70mA https://static.rcgroups.net/forums/a...g?d=1505012827 https://static.rcgroups.net/forums/a...g?d=1505014622 Also here are the scanned manuals: https://static.rcgroups.net/forums/a...G?d=1505014558 https://static.rcgroups.net/forums/a...G?d=1505014561 https://static.rcgroups.net/forums/a...G?d=1505014551 https://static.rcgroups.net/forums/a...G?d=1505014555 I have installed this FPV set on my XLH 9120 RC Car: https://static.rcgroups.net/forums/a...g?d=1505012353 https://static.rcgroups.net/forums/a...g?d=1505012372 https://static.rcgroups.net/forums/a...g?d=1505012389 https://static.rcgroups.net/forums/a...g?d=1505012409 https://static.rcgroups.net/forums/a...g?d=1505012429 https://static.rcgroups.net/forums/a...g?d=1505012451 https://static.rcgroups.net/forums/a...g?d=1505012467 https://static.rcgroups.net/forums/a...g?d=1505012482 Both the Vtx and camera were easy to install. The image is good and since its a CCD camera it performs well under low light situation, The camera feels similar to the one i used on my VRX octane. https://static.rcgroups.net/forums/a...g?d=1505013336 https://static.rcgroups.net/forums/a...g?d=1505013351 https://static.rcgroups.net/forums/a...g?d=1505013367 So Far the only thing i don't like is the stand for the camera that holds the camera with only 2 screw and while it secures the camera in place the camera moves up and down on the Y axis when the car drives over bumpy terrain, so you have to fix the camera in the desired angle with some hotglue There is also a quick unboxing video i made here: Attachment 2231150 https://www.youtube.com/edit?o=U&video_id=J3kA1V4d4XY Manuals: Attachment 2231142 Attachment 2231143 Attachment 2231144 Attachment 2231145 |
Is it still working 3 years later? For this price, it looks great!
Yes still working fine and the image is nice and wide. Also the camera does not change position / does not move around even on bumpy terrain
Giving the fact that this hardware is what you would call a budget friendly equipment, I think this is a great example that you can get good quality for a reasonable price. I wouldn't recommend it to professionals, but I think for a regular simple user this device will be more than enough to do the job. Anyway, thank you for your mini-review, I think reviews are very important for anyone looking to buy something.
I've talked to one of my friends about the KC02 5ghz Transmitter and Camera, and he told me that the system works great! No problem with the initial hook up and test, and it was easy to install on the aircraft. He also told me that he retested it by powering up the aircraft and everything was fine. The latest I bought was a rear-view mirror camera system based on a review I read on https://atfulldrive.com/best-rear-view-mirror-cameras, and I am very pleased with my choice because everything works perfectly.
