Building MQ-9 Drone
Hey y'all!<br><br>Thinking about building myself one of them MQ-9 Reaper drones. I have some parts, but need some help from you professionals out there. <br><br><font size="4"><strong>Parts:</strong></font><br><strong>Frame:</strong> <a href="http://www.nitroplanes.com/projet-drone-2500mm-kit.html">http://www.nitroplanes.com/projet-drone-2500mm-kit.html</a><br><strong>Engine</strong>: Help?<br><strong>Gas tank .etc:</strong> Help?<br>A<strong>V Transmitter & Receiver</strong>: Help?<br><strong>RC Transmitter & Receiver: </strong>Help?<br><strong>RC and AV antennas</strong>: Help?<br><br><strong>About the project:</strong><br>This drone shall be used for airsoft. To observe enemies and such. I want to control it with a laptop, hooked up with a joystick. I will connect a servo to the camera housing, so that I will be able to look around with the drone. It needs really good range, since I will probably be flying pretty far. The reason I have chosen a fuel engine instead of an electric one, is that I can fill it up, and fly. This way I don't need to charge, or keep batteries in the field. Flight time is also increased. I also need a good GPS system on it. So I can make it fly a desired pattern, and so I can set it to drive the pattern when it's not in control by me. I expect to get a pretty hefty flight time with a fuel engine(?). I will control it from the back of a car, with the antennas upon the vehicle. I've seen examples of people achieving 38 hours of flight from a 28oz (2,3 liter) fuel tank, and a 4-stroke engine. <br><br>All help is very appreciated!<br><br>Thanks,<br>DroneGuy
That is a electric only plane as it comes. It could be converted to use a very small gas engine but this would not be simple.
Range is of course limited to line of sight ( less than 2000' ). There is no provision for a camera gimbal or pod mount but you could possibly make something up. |
| All times are GMT -8. The time now is 10:41 PM. |
