Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
14mz pos offset in AFR?
Old 02-09-2011, 02:16 PM
fehringer
Default 14mz pos offset in AFR?
Hello
I am just setting up a new model in my 14mz and so far I have only programmed servo reverse and subtrims (all mixes inhibited). However, in the rudder AFR I am getting a pos offset of 9.5%/2.0% instead of it being centered at 0%, so I am getting in addition to the green chart axis a light blue line offset to the right. I cannot figure out where this offset is coming from. Any help would be much appreciated.
Many thanks
Gerhard
Old 02-15-2011, 09:02 AM
Krysta
Default RE: 14mz pos offset in AFR?
Are you setting up a brand new model? Did you try zeroing out the offset with no luck?
I would try resetting the model and re-entering your data, just in case some other setting is affecting this.
If you are getting this offset on all models, then you need to send this into the closest service center to be checked.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 02-15-2011, 12:29 PM
fehringer
Hello Krysta
thanks for your reply - I have created a new model and I am getting a pos offset of between 1 and 4 on rudder, elevator and aileron. Do you think I should immediately send this in to get checked or would you say that if I monitor the offset closely it should be still ok to fly in the next few days?
Many thanks
Gerhard
