8FG can do this?
My Feedback: (7)
8FG can do this?
Hi Futaba support
Is the 8FG (or 8FG Supper) capable of doing the following function?
Multiple servos controlling a single function can be set up
through the transmitter and then plugged into differently
adjustable receiver channels (even non-consecutively) without
needing a separate servo synchronizer for mixing.
I would like to set up a 35% using this radio, (upgraded to 14 channel) to control the whole servos one for each channel, the idea is not to use a power expander or power system, nor a match box, minimize failure points, and weight, & low cost set up. A wolverine SW will be used to feed the RX through a Sahara regulator with den connector using 2 un-used slots on the RX. The multiple servo control capability will be used to gang 2 aileron servos on each wing halve, same thing for the elevator halves, one channel for each elevator(whic I thing is not a big deal for most radios now days).
I know that this is doable on 12ZAP.
Any thoghts or comments are welcome.
Regards
Regards
