Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
FASST Dual Antennas Install - 6014HS
Old 12-23-2012, 12:00 PM
Jeff Worsham
My Feedback: (28)
Default FASST Dual Antennas Install - 6014HS
Hi-
Futaba instructions warn against installing metal or noise sources near the antennas on FASST receivers. Would that include a metal geared servo? After mounting my antennas, I began to question if this configuration will be OK. Should I change it?
Old 12-23-2012, 12:42 PM
Jeff Worsham
My Feedback: (28)
Default RE: FASST Dual Antennas Install - 6014HS
Or..... Would this way be better? Thanks for your help
Old 12-23-2012, 01:31 PM
Jeff Worsham
My Feedback: (28)
Another possibility is to orient them this way, but still it leaves the metal geared servo and also the pull-pull cables somewhat between the antennas. Looking forward to seeing your recommendation. Thanks again-
Old 12-23-2012, 01:52 PM
karolh
Your option 3 is the prefered method that I use.
Karol
Old 12-23-2012, 03:26 PM
readyturn
My Feedback: (9)
ORIGINAL: karolh
Karol
+1
Rick
Old 12-23-2012, 04:46 PM
chris923
My Feedback: (53)
ORIGINAL: readyturn
ORIGINAL: karolh
Karol
+1
Rick
Ditto!
Chris
Old 12-24-2012, 06:52 AM
Bax
The second and third photos look OK. The first one has the two antennas very close to parallel. That's not good.
