Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Hadron Thrust vectoring question?
Old 09-19-2013, 04:37 PM
whidbey1
My Feedback: (9)
Default Hadron Thrust vectoring question?
Hello
I received my Hadron today, and am trying to program my Futaba 12Z, all is working I assigned rudder as rudder and thrust vectoring as rudder2. It works as both turn with the rudder input. How do I assign the thrust vectoring
to a switch, So I can fly like a normal delta and turn the Vectoring on and off at will.
Bill
Old 09-20-2013, 05:53 AM
Krysta
Not sure if this is what you are looking for or not, but you could do a mix of Rudder2 as master, with Rudder2 again as slave, set the rates to -100% both ways and put this on a switch. When you throw the switch, it will negate any input on that channel.
Sincerely,Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 09-20-2013, 12:47 PM
whidbey1
My Feedback: (9)
One more question, when I am setting up expo, there is expo for the ailerons, but when trying to set up expo for the elevator there is no elevator when using the delta wing setting. Since it is elevons? how do I get the dual rates and expo to work on the elevons for the elevator?
Old 09-24-2013, 11:36 AM
Krysta
If you check in your Function screen, you will see Elevator listed as (depending on your wing type) Aux 7.
So you would go into the ARF screen and set Expo in Aux 7.
Sincerely,Krysta
[email protected]
