2.4 RX Antenna extension to avoid carbon shielding
Hi,
Can I extend one or both of the RX antennae to avoid carbon shielding.
If so - how do I do it.
Thanks.
Brian
Thanks.
Brian
Using the longer antenna does nothing to the range. That's because the antenna is actually the small, bared wire end. The rest is just the coaxial cable leading to the antenna. You would normally replace both short antennas with two long antennas in a large model to get them out of the airframe and exposed to the transmitter.
