10C TX in Glider Mode - Throttle on Ch3?
I'm trying to set up a motor glider in glider mode (2A-2F) on my 10C and the default for Ch3 is "spoiler" which appears to operate off the throttle stick by default. Any reason that Ch3 wouldn't function as a throttle (controlling the ESC) regardless of what the program calls it? I ask because it isn't working, and I'm not sure if it's the "glider mode" or my ESC that needs changing.
PJ Wright
Chattanooga
PJ Wright
Chattanooga
I tested the ESC on another system - works fine! Somehow, I need to swap "spoiler" function fo a standard throttle function in "glider mode." I could go back to "acro", but dreaded programming the "butterfly" mixing of ailerons & flaps. :-/
PJ
PJ
