Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Linking the 617fs receiver
Old 04-20-2015, 04:46 PM
egrave1
Default Linking the 617fs receiver
I have the 14SG tx I had no problem linking the 70008rx but I can't link the fasst 617 to the 14sg tx I go to fasst mult with the letter G plug in the rx then I push the littel btton on the side but it wont link I put a servo to the rx nothing happens
Old 04-21-2015, 06:07 AM
Bax
You have to set the transmitter to FASST 7-channel mode. The R617FS receiver will not work with FASST-Multi coding.
Old 05-24-2015, 05:09 AM
whidbey1
My Feedback: (9)
I am having the same problem. the 12 channel links fine under multi faast, but when on faast 7 channel mode the green light on the receiver only blinks no signal to the servos?
The Receiver (7 channel) is NIB did I get a bad receiver?
Confused
Bill
Old 05-26-2015, 08:18 AM
Bax
Confused
Bill
I'm a bit confused. Which "12 channel" are you asking about? The 12FG or the 12Z should work with the R617FS receiver when they are set to 7-channel mode.
Old 05-27-2015, 05:46 PM
whidbey1
My Feedback: (9)
It binds fine with the R6014hs, not a 12 channel sorry for the confusion. It will not bind with the R617FS.
Old 05-28-2015, 05:39 AM
Bax
What mode is the output set to? You must go into the Linkage Menu, then the Frequency section. You need to set the transmitter to FASST 7ch to link to the R617FS receiver.
If the transmitter is set to FASST 7-ch mode, and the receiver will not link, then you either have a bad receiver or a bad transmitter module. One of the two. If the receiver shows blinking green, that means it detects a valid signal, but is not linked. You should press and hold the link button on the receiver until you get steady green. Sometimes, just press and release doesn't do the job.
Old 05-30-2015, 05:14 PM
whidbey1
My Feedback: (9)
all linked fine this evening, Thanks for your support
