6014HS unlink
My Feedback: (46)
6014HS unlink
Has anyone heard of this before? A friend of mine had a 6014HS unlink, this is what happened. He had flown his Lightning a few days before and all was fine. He started it up taxed to the runway, applied brakes ran turbine up released brakes a little direction correction, went to rotate and nothing. The Jet went off the end of the runway at over 100 MPH. The weeds in the field stopped it after about 300 yds. The turbine was at full throttle and would not respond to a shut off command. He shut the radio off and the turbine kept running, then he turned the radio back on, the radio linked up and killed the turbine. Fail safe was set to shut the turbine off, was checked also if power was lost to receiver it also shuts off turbine. So in my opinion thereceiver was the problem.
It's impossible to say what the difficulty was. It could have been some kind of interference, a power difficulty, but not an unlink. If the receiver came up after cycling the power, the link was never lost. If a receiver unlinks, you normally would have to re-link it.
The most common reasons for radio system problems are in the power supply and its wiring.
