14SG battery - whats the safe voltage point
My Feedback: (10)
Hello Futaba gurus...
I've had my Futaba 14SG since they came out... I'm always nervous about how long to fly.. I typically charge overnight and see that the battery is at 7.1V in the morning (start of flying day)... by the 8th flight or mid-day the voltage (on the display) reads 6.4V. makes me nervous... so I start up the generator and put it on the charger for an hour to bump the voltage for more flights...
I read in a thread about a low voltage alarm... what is that level and is that a precarious voltage level? what is a low "SAFE" battery voltage to continue flying.
any help is much appreciated... thanks in advance.
Hello Frank.
I am not a Futaba guru but I am using the Futaba T14SG and I am using a Robbe Lipo Akku 7,4v 2800mah and can fly for several hours.
Warning voltage for the LIPO is 6,6v. If you use LIFE acc the warning is set to 6,0v and with NIMH it is 5,6v
All according to the manual.
I hope it helps a Little
Kent
Kent
