14SG Problem
My Feedback: (108)
14SG Problem
I just got this radio and I am in the process of transferring planes from a 10 c to the 14. I have a plane that needs ailevator as it has 2 elevator servos. I figured out how to make it work. The issue's are the elevator half's are not moving the same distance and when I use the elevator dual rate one elevator goes up and the other goes down. I have checked the end points and they match. One of the servos is reversed and so programmed. It all worked great with my 10 C but this 14 is causing me some heart ache. Looking for a solution and Thanks
